Other Parts Discussed in Thread: UNIFLASH,
Hi, Dear all, I’m confused by a question for a whole day.it’s about a firmware burning in problem through UNIFLASH.
In debugging process, When the OK.hex is loaded to UCD3138064A’s flash by uniflash, all is OK. Then , I modified the source code , then get Bad.hex, then loaded the Bad.hex to MCU, which lead to the JTAG can’t be connected after the Bad.hex is burned in successfully.
The difference of source code between OK.hex and Bad.hex is only involved in function, not included .cmd.
