TPS2120: How to design the OTG function
Part Number: TPS2120
Hi Expert,
If IN1 is for adapter, IN2 is for USB, the USB port has OTG Spec, does TPS2120 support the function? Do you have the example circuit? Thanks!
  • Hi Jerry,
    The TPS2120 does not have OTG functionality. If this is for a battery application, you can connect the output of the TPS2120 to a battery charger and use the PMID output to charge the battery:
    Would something like this work?
    Arthur Huang
