TPS61193: TPS61193
Part Number: TPS61193
I have a question on TPS61193 PWM dimming input. The datasheet specify the PWM Brightness control frequency range is 100Hz~20KHz. If the input PWM frequency is 130KHz, what would happen? Can the TPS61193 still work? I ever tested by testing with 130KHz PWM input signal, the output is normal.
Thanks for your support.
BR,
Vanessa
