Other Parts Discussed in Thread: TPS23755, TPS23758
θJC and θJB thermal information need
Eric, Please refer to page 3 of the TPS23757 datasheet, section entitled "Dissipation Ratings."
Thank you for your local support of PoE products from Texas Instruments,
Hi Eric,
Since this is an older device, the standard thermal parameters that you see in our current datasheets was not included at that time.
If I were to look at package similar to the TPS23757 with a similar dissipation ratings, I get the below:
ThetaJC top = 24.8
ThetaJB = 39.5
Since this is an older part, I would recommend looking at our newer designs using the TPS23755 and TPS23758. If thermal is a concern, we typically take thermal images of our EVMs to verify optimized thermal performance.
