Other Parts Discussed in Thread: TPS1663, TPS2663, TPS25982
I'm designing a circuit based on TPS259251 IC.
I'm using this IC to protect 5V,5A load. My requirement is the power path should be protected for HIGHER voltages.
That means, if I give 25V input voltage, the protection of the load should be ensured.
Is that possible to use TPS259251 IC for the above requirements?
If that is not could you please suggest me a IC which satisfy my requirements?
