TLV707: TLV707 Question.
Part Number: TLV707
Hi Sir,
Here is spec. from TLV707, I got question for VIH definition, as you can see VIH is 0.9 to VIN, does it mean EN can’t higher than application VIN voltage or VIN recommend operating voltage2V~5.5V? if VIN=3V, EN=3.3, is any issue here?
Thanks, Ian.
  • Hi Ian,
    There won't be any issues if Ven=3.3V and you have a lower Vin=3V. In the EC Table some of our previously released devices have Vin listed in the VIH max because usually if a customer isn't actively controlling that pin then they will connect Ven to Vin, but it is not a concern if it is pulled higher.
