Hi Team,
Please help me answer the follow question from my customer, thank you so much.
As I driven Nch MOS-FET with circuit like attached.
There was a problem that the output of UCC27511A was damaged.
The output pin is shorted to GND (about several ohms). It is a phenomenon that only SOURCE side, only SINK, both are short circuited.
The phenomenon has been improved by setting the GATE pull-down resistor, which is open in the circuit diagram, to 10kohm.
The same problem still occurs.
No problem has occurred up to now to change this resistance to 1K 2.2K, and 3.3Kohm, .
1) Mechanism of failure occurrence.
2) Notes on using UCC27511A.
3) Validity of the current treatment (insert 2.2 Kohm pull-down resistor with GATE).
4) Other appropriate using.
Tom Liu
