Other Parts Discussed in Thread: TL431LI, TL431
Hello. I don't see any mention of maximum capacitance at the cathode of the LT1009. Could there be a stability issue if I connect 10nF, to create an RC filter with the bias resistor? Thanks.
Hi Patrick,
This is quite an old device and we unfortunately don't have that data on hand. Is there any reason you're not using a better and newer device such as the TL431LI?
Abhinav.
We need a part that is available in die form. Unfortunately that's not the case for the TL431.
Patrick,
The TL431 is actually available in die form, just labeled under TL431-DIE.
Abhinav.
