We have questions about TPS62175.
Question 1.
Do you have the data about output characteristics of overload?
For example, waveform or graph of output voltage and output current in overload.
Question 2.
Output current keeps constant and output voltage drops in current limit operation.
Is this understanding correct?
Question 3.
We use TPS62175 and Load SW.
16Vin----------- TPS62175----------(5V)--------------Load SW
Inrush current(1A) occurs when soft-start is finished and Load SW enables.
This IC operates current limit and Vout drops.
Is there possibility that the time from starting current limit operation to recovering output voltage 5V fluctuates when load SW repeats turn-on and off at intervals of 15 seconds?
Please check the attached document.
Takahiro Nishizawa
