In customer's aplication, a new manufactured board is powered up by applying the main 12V which turns ON the auxiliary supplies 3.3V, 5V etc.
In the next step all PMBus components on the card will be programmed.
The concern is for an unprogrammed 53681 to be disabled by default; switching should not occur for the load to be protected
Is the part coming unprogrammed, or if it is programmed, does it need to have xVR_EN actively pulled down to avoid a rail start-up?
Thank you
