TPS65950: Codic audio output has noise occasionally
Part Number: TPS65950
Other Parts Discussed in Thread: DM3730, SYSCONFIG
We meet a sound problem on LogicPD's SOM DM3730 with CODEC TPS65950.  It has a sound bug during pilot test: our device sound outpu becomes abnormal occasionally. Noise will not automatically dissapear until tune off the power. If you repeatedly turn on and off the power about 1/30 chance the abnormal noise will come again.
We cut off the back stage and tested the TPS65950 output wave form when device play a 500Hz sine sound file.
Figure 1 abnormal sound wave
 While the normal wave on other device is bellowing, no high frequency noise.
Figure 2 . normal wave
Then we use logic analyzer sampled the I2S data in TP2 and found when sound abnormal , data is ok!
Figure 3  data collected from I2S when audio abnormal
We collecected the audio wave and do FFT in Matlab to find the noise freq is about 7KHz
Figure 4 FFT result when sound abnormal
Also we can compare the normal one, no 7K componets:
Figure 5 FFT result when normal, only 500Hz and it's hamonical components.
In order to locate the problem, we have tried 2 changes by software modification. one is change the audio sorce sample rate from 8K to 16K. Then the occasion sound abnormal became always abnormal.  We assume there may be some registers configure wrong. But we check it is by read back all the regs value it is the same with another normal device.
Another try is add a manually reset button to reconfigure all the regs when sound abnormal. And it works. Then SW engnieer printed out registers both abnormal and normal, then we found they are the same:
mcbsp clock config:
1. CM_FCLKEN_PER,address:48005000,value:7ffff
2. CM_ICLKEN_PER,address:48005010,value:7ffff
3. CONTROL_DEVCONF0,address:48002274,value:5000040
4. MCBSP2_PCR0_REG,address:49022048,value:f
5. MCBSP2_SRGR2_REG,address:49022028,value:301f
6. CM_IDLEST_PER,address:48005020,value:0
7. MCBSP2_SPCR1_REG,address:49022014,value:0
8. MCBSP2_SPCR2_REG,address:49022010,value:207
9. MCBSP2_XCR1_REG,address:49022024,value:40
10. MCBSP2_IRQSTATUS_REG,address:490220a0,value:4f02
11. MCBSP2_XCR2_REG,address:49022020,value:8041
12. MCBSP2_RCR1_REG,address:4902201c,value:40
13. MCBSP2_RCR2_REG,address:49022018,value:8041
14. MCBSP2_SRGR1_REG,address:4902202c,value:fff
15. MCBSP2_MCR1_REG,address:49022034,value:0
16. MCBSP2_MCR2_REG,address:49022030,value:0
17. MCBSP2_RCERA_REG,address:49022038,value:0
18. MCBSP2_RCERB_REG,address:4902203c,value:0
19. MCBSP2_XCERA_REG,address:49022040,value:0
20. MCBSP2_XCERB_REG,address:49022044,value:0
21. MCBSP2_REV_REG,address:4902207c,value:23
22. MCBSP2_RINTCLR_REG,address:49022080,value:0
23. MCBSP2_XINTCLR_REG,address:49022084,value:0
24. MCBSP2_ROVFLCLR_REG,address:49022088,value:0
25. MCBSP2_SYSCONFIG_REG,address:4902208c,value:0
26. MCBSP2_THRSH2_REG,address:49022090,value:0
27. MCBSP2_THRSH1_REG,address:49022094,value:0
28. MCBSP2_IRQENABLE_REG,address:490220a4,value:0
29. MCBSP2_WAKEUPEN_REG,address:490220a8,value:0
30. MCBSP2_XCCR_REG,address:490220ac,value:0
31. MCBSP2_RCCR_REG,address:490220b0,value:0
32. MCBSP2_XBUFFSTAT_REG,address:490220b4,value:305
33. MCBSP2_RBUFFSTAT_REG,address:490220b8,value:0
codec config:
1. TRITON2_ATXL1PGA_OFFSET,address:a,value:0
2. TRITON2_ATXR1PGA_OFFSET,address:b,value:0
3. TRITON2_ARXR1PGA_OFFSET,address:10,value:3f
4. TRITON2_ARXL1PGA_OFFSET,address:11,value:3f
5. TRITON2_ARXR2PGA_OFFSET,address:12,value:3f
6. TRITON2_ARXL2PGA_OFFSET,address:13,value:3f
7. TRITON2_AVTXL2PGA_OFFSET,address:c,value:0
8. TRITON2_AVTXR2PGA_OFFSET,address:d,value:0
9. TRITON2_VRXPGA_OFFSET,address:14,value:0
10. TRITON2_ARXL1_APGA_CTL_OFFSET,address:19,value:b
11. TRITON2_ARXR1_APGA_CTL_OFFSET,address:1a,value:b
12. TRITON2_ARXL2_APGA_CTL_OFFSET,address:1b,value:b
13. TRITON2_ARXR2_APGA_CTL_OFFSET,address:1c,value:b
14. TRITON2_BTPGA_OFFSET,address:1f,value:0
15. TRITON2_ALC_CTL_OFFSET,address:2b,value:0
16. TRITON2_DTMF_FREQSEL_OFFSET,address:30,value:0
17. TRITON2_DTMF_TONOFF_OFFSET,address:35,value:0
18. TRITON2_DTMF_WANONOFF_OFFSET,address:36,value:0
19. TRITON2_APLL_CTL_OFFSET,address:3a,value:16
20. TRITON2_DTMF_PGA_CTL2_OFFSET,address:3c,value:0
21. TRITON2_DTMF_PGA_CTL1_OFFSET,address:3d,value:0
22. TRITON2_VDL_APGA_CTL_OFFSET,address:44,value:0
23. TRITON2_RX_PATH_SEL_OFFSET,address:43,value:30
I also try to manual reset all regesisters when audio abnormal. After reset, there are some difference:
mcbsp clock config:
8. MCBSP2_SPCR2_REG,address:49022010,value:20f
10. MCBSP2_IRQSTATUS_REG,address:490220a0,value:4f82
32. MCBSP2_XBUFFSTAT_REG,address:490220b4,value:2fd
codec config:
But I think it is causd by reset, not mean to MCBSP configure error.
Curretly we can locate the issue is on TPS65950,because we only re-configure MCBSP when audio abnormal, but after reset audio still abnormal. But the question is why configure value of codec are all right and what cause the audio abnormal?
Thank you
This was firstly post on processors forum (https://e2e.ti.com/support/processors/f/791/t/828610)  But I can not choose audio forum since the part number is TPS65950.
  • Hi Jerome,
    Unfortunately we are no longer providing support for the audio portion of the TPS65950. If resetting the device is a viable solution then we recommend doing so whenever the noise is observed. Sorry, but we do not have any additional suggestions.
    Layne J
  • Hi Layne J,
    Jerome and me are handling this problem, we are very sure this problem is caused by TPS65950, so far we tried our best but fail to solve this problem,
    could you help check following problem?
    1. is this problem caused by internal defect of TPS65950? did your customer meet same problem?is it possible to be solved?
    2.if possible, could you arrange a specified or audio expert to support us?
    your good cooperation is very appreciated.
    thanks.
    Mike
  • Hi Mike,
    TPS65950 is a legacy part and we no longer provide support for the Audio Codec. We may be able to provide assistance with power issues regarding one of the LDOs or DC/DC converters, but we are unable to support the Audio Codec portion of the device. I apologize for any inconvenience this may cause.
    Layne J
  • Hi Layne,
    thanks for your fast response.
    we are from PHILIPS and made use of this component for more than 10 years, this problem actually existed for long time, but now this issue become critical based on product standard, and we have much pressure to fix it as soon as possible, I am very disappointed  that our vendor can't provide any support on this issue, as I know TI is very good at audio area, and have strong internal resource even though this chip is very old. could you please feedback it internally and arrange some resource ? or do you need me to contact  local TI sale representative to feedback this issue by different channel if it's really difficult for you? which way is more useful to fix this problem?
    sorry  to bring inconvenience to you.
    Mike
  • Hi Mike,
    I would recommend reaching out to your local TI sales representative. I am unable to escalate this issue any further, but they may be able to redirect your question to the right team.
    Thank you for your understanding,
    Layne J
