Part Number: UCC27211A-Q1
hi Sir/Miss,
May I know what is the minimum Bootstrap Charge Up time for UCC27211A-Q1 HSD with 0.1uF capacitor?
I cannot find it anywhere in the datasheet.
regards
Wilson.
hi Sir/Miss,
regards
Wilson.
Hello Wilson,
Thank you for the interest in the UCC27211A-Q1. The bootstrap charging path for the bootstrap capacitor is from the VDD capacitor thru the bootstrap diode to the HB-HS capacitor. Also the HS thru the low side FET is the charging path. So the boor diode resistance plus low side FET on resistance and the bootstrap capacitor results in a time constant. t= Cboot x (Rd + Rdson). The boot diode resistance is 0.5 Ohms and boot cap is 0.1uF. If we assume Rdson of 0.1 Ohms then the time constant is t=0.1uF x 0.6 Ohms = 0.06us to reach 67% of the charge voltage.
Please confirm if this addresses your question or you can post additional questions on this thread.
