Hi team,
Could you check what will happen if enable pin floating?
If there is any pull up inside enable pin so the Vout will still ramp up?
Allen
Hi team,
Allen
Hi Allen,
This device does not have a internal pull-up.If it does, the datasheet should state this clearly and allow floating enable when not using the enable funciton. On page 3 under the pin function, datasheet clearly says, if enable function is not used, this pin MUST be connected to IN or BIAS.
Jason Song
