Other Parts Discussed in Thread: TPS61088,
Hello TI,
We stuck in one issue, what is charging voltage in continuous load on
1. 5V/5A Input adapter
2.We use 1S Lithium Polymer battery pack of 5000mAh capacity (as per the manufacturer, charging voltage 4.2V and output voltage is 3.7V)
3. Continuous output Load is 5V/4A (Boost converter TPS61088 Between charger and Load )
In above state what is my battery charging time ...?
1.what is charging voltage ...?
2.what is charging current ..?
3.System output voltage ..?
4. System output current ..?
find the attachment for system block diagram
Thanks and regards,
Rahul surawase
