hi,
Since we have plan to do a power unit with the help of TPS564201,we need TYP volage -5V and what is the input is Requires and if you people have any waveform please share and guide us...
Thanks .,
Parthiban
hi,
Thanks .,
Parthiban
Hi Parthiban,
What's the input voltage, loading? what's kinds of waveform do you want to see? we have lots of waveforms.
You also can refer Webench to do your first design.
BRs,
Edwin.
Hi Edwin,
I am not able to find in our datasheet which voltage we need to feed...my application need only 5V output so i want which input voltage is sufficient for my application at the same time i want to know (i.e) we feed 9V Input what i will get either 4.5 or 5.5 V....i want exact 5 V output is enough....please give me any idea or any reference diagram or reference wave forms....
Parthiban
Hi Parthiban,
Please refer below datasheet. In the datasheet, there is reference design that you can refer.
https://www.ti.com/lit/ds/symlink/tps564201.pdf
The minimum input voltage actually depends on your loading. For TPS564201, 9V input voltage can output exact 5Vout 4A.
BRs,
Edwin.
