Hi team,
Can you answer the following questions by a customer?
"I am testing the use of the TL4242 for a 50 channel LED application. Unfortunately, 500mA nominal current is only available at lower voltages.
Two questions:
1) Can the TL4242 be connected in parallel (similar to Mosfets)?
2) Is there something similar with higher current and similar status output/PWM input?"
Thank you,
Franz
