Other Parts Discussed in Thread: TIDA-01560
Good Morning,
I am trying to design an off-line two output converter with UCC28730 and an Off-The-Shelf transformer supplied by WE : 750811613.
The transformer reasonably matches all the design procedure from the IC's datasheet except for the auxiliary to secondary turns ratio.
What could happen if the auxiliary turns ratio is much bigger than the ideal Nas from the datasheet procedure? From the AN "TIDA-01560" i can guess that it could result in an output lower voltage in some conditions but I can't figure out what they are. Unfortunately it is not much treated in the UCC28730 datasheet and i could not find an AN that can help me on this topic.
Can you please explain what could happen in this situation?
Thanks in advance,
Dario Moscardi
