TPS54424: Design Review
Part Number: TPS54424
I do need the design review for TPS54424 circuit.
Regulator  Design Efficiency
TPS54424 0.84V @ 2.5A 85.12%
TPS54424 1.8V @ 1.4A 90.52%
0.84V:
1.8V:
Kindly help with the design review of the same.
Ranjana Naik
  • Hi Ranjana,
        Can you please share the WEBENCH design for these 2 applications?
    Also, can you give us information on the following.
    1. DC voltage tolerance (% or mV)
    2. Output ripple requirement (% or mV)
    3. Output transient (undershoot, overshoot) requirement (% or mV)
    4. Transient load step size to meet transient (% or mV)
    5. Max operating ambient temperature.
    Gerold
  • Hi Ranjana,
    I have taken a brief look and everything looks as expected. I did not do any actual calculations for the component values but they look to be in the typical range. If you need help with calculating the values I suggest either WEBENCH or the equations in the apps section of the datasheet. If there is any specific challenges you need this design to meet let us know and I can help take a closer look.
    Two component placeholders which would be good to add are:
    1. Feedfoward capacitor in parallel with the top resistor in the FB divider. This can help with tuning the transient response if needed.
    2. 0 Ω resistor in series with the BOOT pin and the 100 nF cap. If you have any issues caused by non ideal pcb layout, populating this with a 2.2-4.7Ω resistor can help.
    Anthony
  • Hi Gerold,
    1. DC voltage tolerance (% or mV) : 12V with +/- 5% tolerance
    2. Output ripple requirement (% or mV) : less than 50mV
    3. Max operating ambient temperature.: Max 30C
    Webench design is as below:
    https://webench.ti.com/appinfo/webench/scripts/SDP.cgi?ID=27B93B0CBD8CBC31
    https://webench.ti.com/appinfo/webench/scripts/SDP.cgi?ID=B066439EB18630A7
    Ranjana
  • Hi Anthony,
    Thanks for the feedback.
    I will incorporate 2 placeholders mentioned - feedforward capacitor and 0 ohm resistor in the design.
    Ranjana
