I see in the typical application section of the datasheet for this voltage regulator that a 1N7021 diode is used. This diode seems to be obsolete/discontinued. Can you recommend a functionally similar diode to use instead?
Thanks in advance.
Thanks in advance.
Hey Tyler,
The diode used was based on the system which had a fairly low output current given the current rating of the diode.
The diode you use should be rated for your output current and voltage stresses appropriately.
Daniel
