The required power will be 50W to 200W.
Dimming is assumed to be triac dimming.
The TPS92561 device can do triac dimming, but is it possible to supply the power I need?
I have a few questions regarding this.
What is the input voltage, input voltage range?
50W to 200W of LED is a lot of light, generally this much light in lighting for equipment for facilities don't use triac dimmers. What is the end application lighting and user interface?
Are you looking for a single power stage or two stage design?
What are the triac dimmers being used? Household triac dimmers are not all that high power so is this a different type of triac dimmer?
I'd like to find out more about your application before recommending anything.
