BQ40Z50-R1: BQ40Z50-R1
Part Number: BQ40Z50-R1
Hello TI,
 Thanks for your support and suggestion, because successfully completed learning cycle and my question is After learning cycle,
  1.When the battery is going to shutdown mode how many days it takes to come from shutdown mode, How to avoid the battery to go for sleep modes.
  2. How the battery percentage is taken which parameter is responsible for showing battery percentage in bqstudio,this is all our customer requirements.
   Please solve my queries,
   Thanks in advance
   Vishwa
  • Hi, Vish
        For Question 1
        When the gauge is in Shutdown mode, you have to apply a voltage between Pack+ pin and Pack- pin no matter how long it has been stayed in shutdown mode.
        To avoid the battery to go to sleep mode, you can the SLEEP bit in DA Configuration register in Dataflash.
        For Question 2
        I think you are asking how to read RSOC from the gas gauge via SMBUS command. To read the RSOC
        You can read the data from the register 0x0D from the device with SMBUS address 0x0b(7 bit address).
  • Hello Stevens
    When the battery is going to sleep mode,how long it will be their in sleep mode,and what is the current value and how to come out from the sleep mode.
    This is what our question.
    Please solve my question,
    Thanks in advance
    Vishwa
