Other Parts Discussed in Thread: TPS23525, TPS23523, TPS23521
Hi there,
is there anny application note that describes how to switch a negative Voltage supply by using a CPU IO, I'd like to supply my analog circuitry from two different negative sources, that I'd like to choose by using FET switch. That means I want to switch the negative side not the ground side.
thanks for helping
