HI
1. Supply power to VCC (VIN) by using Vout pin of MCU.
-> MCU's power supply is supplied by battery.
2. After 8 seconds using PB1, PB2, it gives RESET signal to MCU. Hardware reset of MCU is activated.
3. Occasionally after assembly, TPS3421 malfunctions and reset does not work.
4. If the battery is removed and reattached, the hardware reset operation will proceed normally.
Is there a reason for this?
Is there a circuit improvement method?
