LM36011: Light will be darker when LED STROBE signal have a narrower high level
Part Number: LM36011
Dear TI
Our product use a led strobe signal to light up the torchlight.
The function will be fine when i set the reg(0x01) to 0x15. But i found that the brightness will be darker when LED STROBE have a narrower high level. This is question1
After testing, this issue will be solved in reg(0x01) to 0x1b. But will bring a new question, the light will show a flicker visible (bright to dark, and repeat) to the eye.
I will upload the issue video to the attachment.
Thanks.
  • The video is issue2 situation.
    There is no shark in reg(0x01) to 0x15?
    Weither root cause is the higher sensitivity than the level mode?
      What do you mean by a narrow high level? Have you test the current waveform and the corresponding strobe signal?
  • Hi TI
    May i have your phone number for better communication?
  • Hi lihao,
        You can insert waveforms in the threads or try to find the corresponding FAEs. They will help you in more direct way.
