Hi Team,
I have two questions about LM51501-Q1
1. When LM51501 configured in E-call mode, where does the internal logic power supply come from, VIN or Vout?
2. When LM51501 configured in E-call mode, how does it realize different constant output voltage with the internal feedback resistor? From the datasheet, we can set different Rset value to configure different Vout regulation target. Is the Rset resistor same with or related to the lower side feedback resistor? If so, what is the upper resistor value and what is the reference voltage? If not, could you please explain the principle of how LM51501 realize different constant output voltage? Thank you in advance.
BR,
Arie
