Hi Sir,
Below is TPS25200 output voltage clamping SPEC.Its max voltage is 5.55V.
We have below 3 requirement.Thank you.
- Could you provide the quantity percentage of output voltage clamping is 5.5~5.55V?
- And is there any pin to pin IC that output voltage clamping is lower than 5.5V?
- Is it possible that only provide the output voltage clamping is 5.25~5.5V?
Thanks, Ian.
