TPS62290: Response Time of EN Pin
Part Number: TPS62290
The response time for the EN pin depends on the load conditions, but could you please tell me the response time(the time to transition into shutdown mode and the time to return from shutdown mode) when the EN pin is asserted and de-asserted?
Kato
  • Hi Kato,
    The response time needs to be measured in the lab. Hence, I would come back with the measurement results by tomorrow.
    Febin
  • Hi Febin-san,
    Thank you for your quick response.
    I am looking forward to getting the update from you tomorrow.
    Kato
  • Hi Kato,
    I have measured the response time of the device using a standard EVM with Vin 6V when the EN pin is enabled and disabled.
    The time taken to turn on the device would be 267 us and to turn off the device is 82 us approximately.
    Please find the plot below.
    Febin
  • Hi Febin-san,
    Thank you for the information.
    I have an additional quesiton, so could you please tell me the minimum pulse width for EN pin when the EN pin is asserted and de-asserted?
    For example, does TPS62290 start up normally if the high level of the 10us pulse width is applied to EN pin ?
    Additionally, does TPS62290 shut down normally if the low level of the 10us pulse width is applied to EN pin ?
    Kato
  • Hi Kato,
    May I please rephrase your question again, you are applying a 10us pulse width signal to the EN pin and expecting the device to turn on with its High and turn off during the transition to low level.  The above measurements are taken at specific conditions and can be used only as a reference. For the above measurement, Vout reaches the desired value much later than 10us, hence the device needs to have a higher pulse width signal to turn on. Similarly it will take more than 10us to turn off. Please provide more details if the answer does not clarify your question completely.
    Febin
  • Hi Febin-san,
    Thank you for your response.
    According to TPS62290 data sheet, the electrical characteristics related to "start-up time" and "Vout ramp-up time" are specified as follows.
    So, is my understanding correct that TPS62290 cannot start up if the high pulse width for EN pin is less than 250us?
    Additionally, if the high pulse width for the EN pin is 400us, TPS62290 can starts up but the output voltage cannot reach 100% of Vout. Then, TPS62290 shuts down. Is my understanding correct ?
    On the other hand, how does the TPS62290 work when the TPS62290 is operating normally, for example, if the EN pin only goes to low for 40us?
    I don't have the TPS62290EVM-279, so could you please actually check the operation using EVM?
    Kato
  • Hi Kato,
    Yes, you are right.
    Could you please clarify on what you mean by Normal operation? May I also know your Application and the conditions for which you would like to measure the EVM?
    Febin
  • Hi Febin-san,
    Thank you for your support.
    Could you please test the following scenario(case #1 ~ #3) with TPS62290EVM-279?
    The VOUT behavior is what I would expect.
    Kato
  • Hi Kato,
    Please give me some time to check the EVM. I will come back with the measurement results next week.
    Febin
  • Hi Febin-san,
    Thank you for your strong support.
    I am looking forward to getting the measurement results from you early next week.
    Kato
  • Hi Kato,
    Please find below the measurement results as per your requirements.
    Case 1:
    Case 2:
    Case 3:
    Case 4: Vin: 3V, Iout: 500mA, EN_low: 40us
    I have added one more case just to compare the output with some load. Please note that the above measurements are only for a particular case and can be regarded only as a reference.
    Febin
  • Hi Febin-san,
    When the output is no load, the output voltage is kept as the charge on C10 isn't discharged under the case 1 and case 3 even if EN is de-asserted to low.
    Kato
  • Hi Kato,
    For Case 2 and Case 3 this is correct.
    Febin
  • Hi Febin-san,
    Thank you for confirming.
    I understand.
    Kato
