What happens if OUT1 or OUT2 is driven externally by mistake and the driving voltage is higher than the input voltage, will it back drive the IN pin?
Hi Nicholas,
Thank you for posting your question. The expert covering this device is located in China so please expect a slight delay before a response. Thanks in advance for your patience.
HI Nicholas,
If the device is disabled, then the power switch is block.
If the device is enabled, then the current will flow from OUT to IN.
Feifei
If unpowered, VIN=0V or EN=0V, will block reverse current.
For TI's policy, I will first click resolved button.
If you have any other concern, contact me any time.
If you think resolved, please help click 'Issue is solved button'.
Thanks.
