TPS92691EVM-001: recommended PWM frequency
Part Number: TPS92691EVM-001
What recommended PWM frequency for this board in option LOW side current sense resistor? Is it possible 100:1 dimming?
    From our previous communications, I assume that you are talking about the Sepic evaluation board.  Is that correct?  Can you please give me the specifications that you are trying to design to?  Why are you doing low side current sensing?
    When you are talking about the PWM frequency, are you talking about the PWM dimming frequency or PWM switching frequency?
    Thanks Tuan
    We have not heard back from you so we believe you may have solved the issue.  The thread will close now but will reopen if you reply.
    Thanks Tuan
