Other Parts Discussed in Thread: BQ76PL455EVM
Hi All,
We have bought the BQ76PL455EVM and module is connecting through USB/RS232 to the computer . BQ76PL455EVM-GUI can not connector ( unable to connect com port ).
The cable is connect right, when I measure(oscilloscope) all 4 signals (RX,TX,RTS,CTS) there is no change (nothing).
But when I use other software e.g. terminal emulator all is OK com port is working.
The problem is in BQ76PL455EVM-GUI because output from com port is no changing at all - nothing - no signal.
GUI is installed from Texas sluc584a.zip and com driver from FTDI CDM21228_Setup.zip.
Is there some special setting fo Com port ( bitrate, parity, flow control and so?) I am using (9600, 8 bit, no parity, 1 stop bit, none flow contr.)
Thanks in Advance.
Ivan
