Other Parts Discussed in Thread: INA226, TPS25982, TPS2595, TPS25942A
We have to design a circuit board to provide multiple low voltage power supplies to a large amount of DUTs.
We have 40 DUTs that require 1.2V(50mA max/per device) and 2.5V(100mA max/per device) each.
We would like to be able to power the device independently, to measure the current consumption for every voltages and to protect the devices in case of fault (short-circuit, over current…).
We should be able to read the PS status and currents and to switch ON/OFF every DUTs independently using I2C bus.
Trying to find the right components to design this PS board, we found out the LM25066 that seems to fit our need for channel selection and protection.
Using other TI components, we plan to use the attached (pdf) topology.
Do you have any advises/comments concerning the topology or the components selected. Do you have other components in your catalog for our application?
We plan to produce hundreds of these multi channels power supplies.
Best regards.We have to design a circuit board to provide multiple low voltage power supplies to a large amount of DUTs.
Best regards.
