Dear sir,
I'd like to use TPS79850 as a 5V regulator.
So I'd like to confirm following usage is correct or not.
1. If the EN pin becomes low, then this device will become shutdown mode.
When the shutdown mode, I think this device can provide "no output" is correct?
2. Does EN pin have internal pull down? Should this pin have anything care?
3. For SENSE pin, can I connect this pin to OUT pin directory? (It means is it require voltage divider registor?)
