what is the difference between TPS211x and TPS211xA parts?
Thanks.
Hi Ewald,
Thank you for reaching out to the E2E forum!
The TPS211xA series is a spin of the TPS211x series. This makes these devices nearly identical. The only difference in the devices is the switch-over rising propagation delay. This means that the TPS211x series takes longer to switch between one input to the other, resulting in a voltage dip on the output. With the shorter rising propagation delay in the TPS211xA series you can mitigate the voltage dip seen at the output for a seamless switchover. This is useful with loads that can go through a system reset in the case of an under voltage condition.
I hope this helps!
Andy Robles
