Other Parts Discussed in Thread: BQ25570
To operate this bq25570 evm board, I am not sure what I need to do is supply power to the board or supply voltage. I tried to charge the VSTOR by supplying a voltage to the VIN_DC terminal with a power supply device, and through it to power up the board. However, the VSTOR value did not go up and changed even if the VIN_DC terminal was loaded with a lot of voltage So I want to know exactly what to do to get the board up and running. There are many things I don't understand to just look at the data sheet.
If I have to put in power instead of power supply by running the board, I would like to know if I should have a separate source meter and supply current to the VIN_DC terminal as well.
