Hi All,
Can I use a pullup resistor on the output without powering on the IC? (And I am hoping the output is HZ when the IC is powered off)
Thanks and Regards,
Nishanth A B
Hi All,
Thanks and Regards,
Nishanth A B
Hi Nishanth
You can use a pull up resistor without powering on the IC . The output is in high Z so you will get pull up supply voltage at the output.
Trailokya
