Hello
I Request a Design Review about attached Schematic File
Best Regards.
Hi Louis,
Before reviewing your schematic, can you provide more information on your application? What in particular are you having questions with?
Alejandro
Hi Alejandro
This application is POTN (Packet Optical Transport Network).
We need confirm of schematic before manufacture.
In particular, please review the current sharing section in detail.
Best Regards.
Hi Louis,
Understood; thank you for clarifying. I will be reviewing your schematic and will get back to you as soon as possible.
Thank you for your patience,
Alejandro
Hi Louis,
I reviewed the current sharing section alongside the rest of the modules. One thing I quickly noticed is that you have the same amount of output capacitance and and TurboTrans resistor values across devices. That already was a concern since the calculations on selecting the correct values for PTH08T250 and PTH08T210 are completely different. Please make sure to review both sections, Adjusting the Output Voltage and TurboTrans Selection, for both devices. That will provide a more detailed step-by-step guide on determining the correct values to implement on your design.
Note: Please make sure to double-check my calculations by using the appropriate equations or tables provided in the datasheet.
Alejandro
