Hi, team.
We use PTH08T220W with 5V output.
Please tell me Rtt and Cout at 5Vout.
20SVPF560M is planned for Cout. What is the optimal Rtt?
Hi, team.
Hi Hirotsugu,
I will be contacting our team in regards to this and provide you with the required values as soon as possible.
Thanks for your patience,
Alejandro
Hirotsugu,
Can you provide more information on your application? What is your input voltage and desired transient voltage deviation?
We would like to make sure you are using the right amount of output caps to meet your desired transient, which leads to the correct Rtt value.
If your application is planned/set for an output capacitance of 560 µF (as you mentioned above), then we recommend Rtt = 33.4 kΩ.
Alejandro
Hi, Alejandro
