Hi
It seems that VIH and VIL spec in datasheet had been put with wrong position. Would you please help check that the VIH should be referred with MIN, VIL should be referred with MAX.
http://www.ti.com/lit/ds/symlink/tps65192.pdf
Thanks!
-Rocky
Hi
Thanks!
-Rocky
Hello Rocky,
Yes, it does appear that VIH/VIL levels have been put in the wrong column. VIH spec should be 2.0V min and VIL spec. should be 0.5V max.
We will make a note of it correct it in the next revision of datasheet.
Kind Regards,
Liaqat
