Dear TI members,
We are currently using your LP87564 to supply a TDA2p processor. Due to some EMC problems we have found that we need to add ferrite beads at each one of the LP87564 outputs, just after the LC filter. But this solution is generating a new issue. The high current demanded by some of the TDA2p voltage rails is generating a voltage drop in those ferrite beads, which is getting more critical at high temperatures.
We have tried to do a remote sensing of the DC signal by connecting FB pin after the ferrite bead. This seams to be functional at least in room conditions, but if we check the switching signal of the buck converter we can see that the PWM is not stable in the first seconds after power up and DC regulation is not very precise. It looks like the inductive part of the ferrite bead is affecting the feedback and it takes some time to adjust and lock the feedback loop.
Do you know if it is possible to adjust the LP87564 to perform this remote sensing?
Do you know if the AVS and other power management tools of the TDA2p would be able dynamically compensate this voltage drop?
BR,
Vicent Climent
