LM3630A: Why the inductance exists whistle ?
Part Number: LM3630A
Hi TI team,
         My customer used LM3630A for Led driver . The Vin of LM3630A in their borad is 3.6V-4.3V and the number of led which maxium current is 10mA is 8. They found that the inductance exists whistle
once the led lights. We will be appreciate if TI can help us to solve the whistle issue . Thank you!
         By the way. The following picture is their schematic.
  • Hi Troyson,
        For your schematic, you have floated the "PWM" pin? How to achieve dimming? You need to connect the"PWM" pin to achieve the current dimming. ( Or connect the "PWM" pin to a high level)
        Are you toggling the "HW_EN" pin?
        And since you just use one channel, have you disabled another channel?
    BR
    Sean
  • Hi Troyson,
        The dimming is controlled by I2C(Register_. Brightness A)
        Yes.Customer input high level to enable the device .
        They do not connect the another chanel ,The led2 is floating
         Besides, we have tesed some waveforms. Hope it's good for you . We can find the frequency in Picture.1 & Picture.1 is <20khz which may cause the sounds
         Picture.1 The waveform in D3 (Diode)-2 pin
       Picture.2 The waveform in  ILD1 pin
          Picture.3 The waveform in SW pin
         Picture.4  The waveform in SW pin
         Picture.5 The SCH
  • Hi Troyson,
        Picture 1-3 can't show now and you need to disable the channel two with the regs. reg0x00= 0x84; reg0x01=0x08.
        And have you read the reg0x0B? this is a fault register that may have some information.
    BR
    Sean
  • Hi Sean ,
            OK.  Customer just used LED1.But they enable the 2 led chanel . So If customer float the LED2 pin .The deveice will work abnormally?
  • Hi Troyson,
        No, it will detect the open led and works abnormally. Please disable the LED2 with regs if they don't use this channel.
    BR
    Sean
