I am looking at https://e2e.ti.com/blogs_/archives/b/precisionhub/archive/2016/09/02/give-your-voltage-regulator-the-margin-it-deserves
I tried to simulate this. But, my output doesn't go higher than 5V. In theory, Vout = Vref*(1+R1/R2), when DAC output equal to 0, then how is it goes to 5.5V? I want to get the same results as Figure 5 in the link.
I also tried to use this equation with Vref=0.8V then, I lost the upper margin when I computed R1 based on R2. This is almost fixed wrt Equation (1) and (3)
Would you correct me if I am wrong? and also if possible, would you share the simulation file to test?
koho
