TLC5941-Q1: audible noise when using TLC5941
Part Number: TLC5941-Q1
Other Parts Discussed in Thread: TLC5941
Hi Sir.,
my customer uses 10 TLC5941 to drive 160 LEDs for backlight. They use PWM mode with 6MHz GSCLK. below is the waveform. it looks correct for me.
They drive all LED in the same PWM setting.
Ch1: one of out pin
ch2: BLANK
CH3: GSCLK(it should be 6MHz. due to scope resolution, the frequency in scope is wrong.)
They can hear the audible noise.
Do you have any suggestion to reduce it?
BR,
frank
  • The hawling may trigger by the output cap because the frequency of vout is with the human audible range, you can increase the frequency of vout to 20k to identify
  • hi Frank Qiu,
    Change GSCLK to 24MHz and Blank to 20KHz. but the PWM step is only 1024. The audible noise becomes very small. 1024 steps seems the max steps for this asic to avoid the audible noise.
    Can I know if this is the only solution?
    Audible noise issue should be very normal for this application. How does other customer fix this issue?
    BR,
    frank
  • From my opinion the source of noise is the output cap , could you help me to double confirm it?
    There are two ways to solve this issue:
    1) change the frequency of vout out of the range of human audio
    2) change the ceramic cap to electrolytic cap or tantalum capacitor
