Other Parts Discussed in Thread: TPS92512, TPS92513
Hi team,
The problem is that output waveform is not stable. When they configure output frequency to 130kHz with Vin 56V, Vout 48V, 1A load and no PWM dimming, the duty cycle varies in time domain.
Besides, here is some questions arising from my customer:
1.In our datasheet, we have COMP pin for compensation. Can we connect Res/Cap for compensation? Do you have some calculations here? Otherwise, do you have small signal model base of this device?
2.In our datasheet, we have slope compensation structure inside. Can you offer more details about slop compensation?
3.Do we have maximum duty limitation inside our IC?
Jimmy
