Hi team,
Please kindly advise the below.
- Why is between 5 and 8 pin placed not only bottom but also lateral ?
- Is solider fillet mandatory ? There is no problem if the bottom side is mounted ?
- If solider fillet is mandatory, are there any conditions for solider filet ? It is ok to follow the datasheet ?
- Are there any problem if solider bridge is seen between 5 pin and 8 pin ?
- Are there any problem if via is placed at bottom for drain
Thank you and best regards,
Michiaki
