Other Parts Discussed in Thread: TPS65023
In my design Im not using PWRFAIL _SNS and PWRFAIL pins. Can i keep these unused pins open?
I have forwarded your request to Applications Engineer supporting this device.. He is in US time zone and he will provide you the feedback by today or latest tomorrow.
Murthy
Yes, you can leave both the PWRFAIL_SNS and PWRFAIL pins floating (NC).
PWRFAIL_SNS is a Hi-Z input into a comparator.
PWRFAIL is an open-drain output. The FET will be on (pulling low) but there is no voltage source so it will not consume current.
Any pull up to EN_DCDC1 is required if Im connecting Power good on another regulator to this pin?
If PWRFAILz (output) is used, it requires a pull-up resistor to an I/O voltage (1.8V or 3.3V) because it is open-drain.
If PWRFAIL_SNS (input) is used, it typically requires a resistor divider so the measured voltage goes above the 1.0V threshold when the input voltage exceeds a different threshold. For example, if you were monitoring VIO = 3.3V, you may calculate a resistor divider such that:
The exception would be if you are measuring VCORE = 1.1V, you can connect VCORE directly to VPWRFAIL_SNS or with an RC delay added to delay when the 1.0V threshold is crossed for the comparator (which delays the PWRFAILz output signal.
In my design, DCDC1 output voltage is 1V. How can I enable EN_DCDC2?
Can i use PWRFAIL pin to enable EN_DCDC2?
If you refer to this App Note: Power Supply Design for NXP i.MX 7 Using the TPS65023
It is using a similar part (TPS65023) with an analog sequencing circuit.
In your case, you want DCDC1 to be enabled first (VIN connected directly or through a Schottky diode to DCDC1_EN).
However, if you generate exactly 1.0V it may not be enough to trip the PWR_FAIL_SNS comparator. Also, the PWR_FAILz output is commonly used to release the PORz input of the SoC that is being powered.
My recommendation for enabling DCDC2 would be to:
Connect VIN to EN_DCDC2 through an RC delay --> VIN connects to resistor (100kOhm), and the opposite side of the resistor connects to a capacitor (0.1uF ) that needs to be charged before the EN_DCDC2 pin "sees" a high logic level (VIH). R*C = (100kOhm)*(1uF) = 10ms, but with VIN =5V*63% = 3.15V the voltage at EN_DCDC2 will be greater than VIH in <10ms.
This way, DCDC1 is enabled first by VIN and DCDC2 is also enabled by VIN after a delay, which will allow DCDC1 time to reach the target output voltage (1.0V) and stabilize before DCDC2 begins to turn on.
