Hello TI,
I am using BQ34110 ic with STM32f4 series MCU. I am not using BQstudio software ,but i had done initial edits in some register using I2C commands which was instructed in document released by TI.
I am using two Li Ion batteries of 4.2V with 2200mAh specifications in series with my MCU board. my question is that,
1. As same current is flowing through both batteries , Do I need to perform current calibration? Can I keep default values of CC gain and CC delta for this setting?
2. When I tried to read design capacity with 0x3C, it gives correct answer, but with same code when I tried to get average raw voltage value using 0x7C, it is showing 0 everytime.
3. can you share values of CC delta, CC gain, voltage divider value(as max. voltage from battery should around 9000mV) with known force current of 500mA and known voltage applied =7040mv
