I’m planning on using the LM22672-ADJ but can’t seem to get this modeled in Web Bench. I’m planning on using this part at 12Vout with a Vin = 18V to 36V. Web Bench is trying to constrain me to use 5V as a max Vout but the datasheet says you can use this part at higher output voltages due to the adjustable nature of it. Can you provide some insight as to modeling this properly at 12Vout in Web Bench? Thanks in advance!
