TPS61193-Q1: TPS61193
Part Number: TPS61193-Q1
Dear TI team:
         Because of  the minimum brightness requirement in night mode, the Riset resistor of our backlight circuit uses a 196K ohm resistor。
But  spec required for normal operation, resistor value from 24 kΩ to 129 kΩ must be connected between this pin and ground。
I would like to consult if there is any risk of Riset exceeding 129K ohms。
The following is the schematic diagram of our backlight circuit,thanks!
