Other Parts Discussed in Thread: LM61440, LM61460
- According to LM61440 datasheet, When Vout is 5V and fSW is 400KHz L1 should be 8.2uH. But in the EVK design, the inductor value was 4.7uH. Could you please elaborate on this?
- In the EVK layout design, I noticed that you moved all the VIN_EMI to the bottom side of the PCB while you can keep it on the top layer and made a keepout area in the top layer and layer 1. Could you please elaborate on this? Is it for isolation purposes?
- Also, I noticed that you shielded the VIN traces with GND vias but you didn't do the same with the VIN_EMI. Could you please elaborate on this?
Thanks..
Mahmoud
