The data sheet refers to the case temperature in multiple places, but I cannot find the Theta-J Case specification. Is this available?
Stuart
Stuart
Hi Stuart,
Thanks for the inquiry. TI does not specify RthetaJC for this SO8-packaged dual FET. The only specs we provide in the datasheet are RthetaJA and RthetaJL (junction-to-lead). The primary path to remove heat from an SO8 is thru the leadframe - pins - PCB. We typically do not spec RthetaJC to the top of the package. The closest comparable I have is for a 5x6 wire bond SON package. Based on the die size, I would estimate RthetaJC to top of the package around 30 to 35 degC/W.
You may find the blog below useful. I'm going to close this thread. Please contact me via regular email if you have additional questions.
John,
Thank you for your response. I performed some comparative testing by looking at the drain lead temperature on one of the FET's (compared to the case temperature). I can confirm that your guess of 30 to 35 degC/W are in line with what I observed.
Stuart
